Trunk pan finishing
dodge68charger
7:33 PM
Washington
Just wondering what everyone did for their trunk pan finishing. Just wondering if theres a good quality coating thats durable n looks great when finished!
Not too concerned about authenticity. Im thinking something like a rhino liner but not sure how it will look
on nonrestoration cars i use bed linner.nothing will damage it and it looks nice.
Sprayed in SEM Rock-it Bedliner in the trunk and entire bottom of my Roadrunner, Coronet, my truck bed and a couple friends vehicles. Tough as nails, has a nice textured look, comes tintable and is a sound deadener. If you go that route, don't waste your money on any kind of roll/brush on bedliners. There is no comparison between them. Buy a couple cans of trunk spatter paint if you want to dress it up. Toss on a couple coats of Rust bullet or POR15 before the bedliner and your trunk will be rust free for many many years.
SEM kit is $100 bucks. Comes with the gun, 4 quarts liner, 1 quart catalyst, mixing cup (tintable kit also comes with Sem-sol). Very easy to do if you can manage taping off over spray areas, use sand paper/scuff pads and dial in a little regulator to the proper psi that comes on the directions. Need a medium sized compressor, 25-30 GAL would be big enough. A trunk will only use up about half the kit.
http://www.amazon.com/gp/product/B003WRY5MW/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B003TQFBN8&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=03MDYNHEH5YTD26K855K
Good luck whatever route you go.... Roadrunner Trunk with SEM Rock-it:
No problem....You heard right. SEM is a professional line of products with good results. Cost is obviously higher than the mainstream stuff, but you get what you pay for. Good luck, I hope your project goes well.
I did the same, spayed the whole bottom of the car, floor boards and trunk with PPG Epoxy primer and then spray on bed liner. Worked great
