Dibbons
- 3:58 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I seem to be short some screws here, could have been the previous owner lost 'em, not sure.
Specifically my questions are:
A) I have four 1 3/4" screws (above bottom right) that I assume go to the plastic bucket seat back. However, the plastic seat back has six holes, two of them are up high on the back behind the head rest and four (two on each side) on the arms that the seat back swings on. Which holes do these 1 3/4" screws go into? And am I missing two screws the same size or do I need two small screws?
B) How does that little metal bracket (above middle bottom) go on for the push button? I assume it goes on the inside of the plastic seat back. What size screw(s) holds it in place? There also is a round black rubber gasket (above middle center).
C) The seat back latch (above right) has an oval "washer" or "spacer", does that go under the latch or on top? Do those two lock washers belong on the oval washer or somewhere else?
D) Anything else I need, or any other hints on getting this back together?
Thank you.
Thank you.
