jogirob
I tried using Duplicolor Vinyl & Fabric dye on the lower portion of my 74 Charger SE door panel. While it worked great for the upper portion & armrest portions (leather/vinyl?) the bottom plastic panel gets dinged up way too easily. Should've known better :doh:
I sanded enough to remove the loose stuff and prepped the surface w/ the Duplicolor wax remover solution and even sprayed it down with an adhesion promoter. What type of paint should I use on these old plastic panels? Any other protips? Thanks.
