Huicho417
- 11:58 AM
- Sep 15, 2020
- San Antonio , Texas
I am trying to figure out where my oil is going. Not a drop of oil on the driveway when I park the car for several days. When I check underneath, there is a drop that looks like its coming out of the transmission inspection port. Could this be from the rear main seal? If so, would it only leak when driving? I recently added an oil catch can because I thought I may have excessive blowy by sucking oil vapors out. I changed the oil this weekend after about four months (i only drive the car every other week around town) and the can had 90 milliliters in it. Does this sound excessive? I also just added an ME Wagner dual flow adjustable PCV valve just in case I am building too much crankcase pressure pushing oil past the seals. I did notice oil residue around the valve cover filler cap and bolts. Only time will tell is this alleviates the issue.
I forgot to mention that the car does not smoke at all, idling or when cruising. Has anyone dealt with a similar situation?
