patrick66
On my '66 Coronet 361 engine, my oil is vanishing. I'm finding no signs of leaks and no puddles. I drove the car a total of 555 miles over two Saturdays this past month. I did an oil change about two months ago - new Wix 51515 filter and five quarts of 10W-40 Castrol GTX. I've used both for many years without issue. The engine has about 70K miles on a 1983 overhaul. It runs beautifully, with no hiccups or hesitation. I can leave the car in my shop for weeks at a time, and it starts with two pumps of the pedal and maybe two revs of the crank.
I went to pull in my driveway last Sunday, and when I got slowed to about five mph, my oil light came on...****! It idled for a few seconds and the light went out. Since I was about 500 feet from the shop, I gently drove it up to the shop door. Light stayed out until I turned the car off.
I had maybe a quart in the sump! WTF, over?
With that, I'm not finding anything obvious as to where my oil is going! To have oil consumption at roughly 125 miles/quart is pretty mysterious. No smoke at all. There is no oil residue on the back of the car, and no oil under the car. There has always been a very small leak at the back of the pan at the corner, not the seal. I had a leaky driver-side valve cover leak I fixed with a new gasket a couple of months back. The loss of oil I'm speaking of is post-gasket replacement.
Fastest I drove was 85 mph or so, and the highest RPMs were right at 3300. The only thing I can think of is high crankcase pressure, which is blowing oil out somewhere. I've got another PCV valve I'll try and see at that point, what's up.
Any of you have any ideas?
