- 1:37 PM
- Apr 13, 2012
- Granite Bay CA
I have a mismatched brake system in my 70 Charger. It started out out in 2000 as an experiment to see what parts I could use from various A body cars in wrecking yards. I found that the 73-76 A body brake booster and MC fits, so I used that along with 11" rotors. It was a great improvement over the original 4 wheel drums so I stayed with it.
I currently have 12" front rotors with 2.75" calipers. The rear is a disc kit offered by Dr Diff consisting of 10.7" Toyota rotors and 1.75" Mustang calipers. The car stops okay but not as quickly as a non power front disc A body. Years ago I tried a switch to manual brakes and had bad results. I tried 4 different master cylinders and each one gave me a hard pedal with poor stopping ability. It was very confusing because in theory, everything made sense for it to work. I looked at brake pedal ratio calculations and found that the manual brake A body had a 6.92 to 1 ratio and the B body had a 6.6 to one. The B body ratio should have the advantage yet my brakes were not reacting enough when I stood on the pedal. I gave up after awhile and put the power equipment back on. Braking is again "okay" but still below what I want. I added a vacuum pump since the lumpy cam I have produces about 5 lbs of vacuum at idle in gear.
I've read that some people suggest to drill a new mounting hole in the brake pedal lever above the stock hole. I found that the center-to-center of the brake pushrod hole to the mounting point is 1 7/8". A move to 1 1/2" changes the ratio from 6.6 to 8.125.
I have a spare brake pedal assembly and am considering giving this a try. I figure that I'd try seeing if this helps with the power booster still in place. In reality I'd prefer to eliminate the power equipment for a simpler system but I'm still gun-shy since I had terrible luck before.
