I think cooling fans is a difficult topic. If you have a fan that is badly designed you'll need a lot of amperes to move any air (you need brute force), while a correctly designed fan will move lots of air with less Amperes. The shape of the wings is very important.
I have noticed in other non-automotive fields that there are a lot of fans out there which are designed without any consideration to air flow and efficiency, they just want to sell stuff.
For example, bathroom ventilation fans, my latest quality fan: I can hear when starting the fan that the shape of the wings doesn't work at low speed, but when the fan reaches operating rpm the sound changes and suddenly the shape of the wings is correct and it starts moving lots of air!
I'm heating my house with a modern wood burner, it uses a fan for air flow through the burner. The fan itself is badly designed, I can see how the soot deposits on the wings. It's clear that the air flow is bad, and the fan is just manufactured, it's not designed for efficiency in any way. The burner is just using brute electrical force to move air, and probably uses 3x more electrical power than necessary for the amount of air.
Some data stating air volume moved per Ampere would be a great help comparing fans.
Considering the shape of the wings, I think submarine propellers and wind turbines show the way to go.
Some electrical comments...the amp gauge is not so picky about the size of the current. The needle is just moving in a magnetic field and cannot burn. The current inside the amp gauge is moving in a thick bar (no thin copper wire) and will not burn easily (other things will burn before this bar). The critical stuff is the screw terminal connections (need to be clean and tight) and the size of the wires.
Upgrading the alternator and corresponding wires is probably a must when starting adding electrical cooling fans, electrical water pumps, electronic engine management. Just my engine management is consuming 15 Amps at idle (injectors+coils+electronics) so already with a mechanical cooling fan and water pump, adding some more powerful headlight bulbs and the original alternator is already working hard...
