I have a 1971 dodge Charger SE 383. I am converting to MSD plug in play (part#8386). I have checked the forum and could not find the exact answer. Also the wiring diagrams I found on line are slightly different than mine. MY question is the MSD 8386 does not use a ballast, or ignition module. (See attached MSD installation pic). Has anyone put a MSD 8386 on a 1971 charger 383 or similar. Also my old wiring might be jacked?(see below ?'s and pic)
Here is my current wiring(See attached)
Starting on the orange ignition module on the left side at 10 O'clock position is a brown/white stripe wire that went to my black wire on my old distributor(stock), at 8 O'clock is a white/ black stripe wire that went to the white lead on the stock distributor. FIRST Question(1)-What do I do do with these two wires? At the 6 o'clock position is a gray/yellow wire that goes to the left side of the ballast which is tied into the alternator wire. At the 4 o'clock position is a black/yellow which went to the negative side of the old coil.Second(2) question is this the ground and does this now go to the new ground(black) pigtail to new MSD coil? At the 2 o'clock position is a green/red stripe- that went no where. THRIRD(3) where does that go?
Moving to the right side of the ballast is a brown wire that went to the positive side of my old coil. Fourth(4) question is this the power that now goes to the positive+ side of the new coil. Fifth(5) question there was also a brown wire from the bottom of the fuse block that went to the negative-side of the old coil. IS that the tach wire and should that now go to the Gray tach input lead to the new distributor? Then last question -Unplug the leads going to the ballast correct? Thank you in advanced!
