Year one engine harness
Mopardreams
2:42 AM
Tennessee
Ok so got a new engine wiring harness was able to tell where most went except a few.i don’t have the grey wire with the black connector on my original harness. And the pic with the three wires together I don’t know where they go either. Can you please help
I don't know but you may want to tell us what car it is and maybe what harness part number you bought.
You could also check the wiring diagrams in the Factory Service Manual and see if those connects show up there.
If it came from Year One, it is most likely a M&H harness. They have a tech line you can call.
Car is a 1970 roadrunner 383. It is a m&h harness.
^^ Yep, need some more info. '70 Coronet? Is that the middle bulkhead harness?
There should be a single wire coming out of the firewall that connects to the short grey wire with blk stripe near the harness. The 3 wire group I believe two of those wires go to the coil and the third I am not certain about. I believe it attaches to the diaphragm on the distributor.
