rumblefish360
I posted a reply earlier but it didn't make it I guess. Thanks for the great advice and info guys. 64Bel, I agree completely. I am taking my time and enjoying the ride. I knew when I bought it that it would take awhile to get it on the road. Rumblefish, AMAZED at the story, I think it changed my mind completely about making a switch.
Well, the car was payed for and the keys were mine to use and drive the car away with before the story was told. I have no reason not to beileve him not to mention the record keeping he showed me after I payed for the car.
The 318 lacks torque and is sensitive to cam size, cylinder head port size and carb size. The basic 3 c's of performance. (Compresion, cam & carb)
Use the K.I.S.S. method and take it easy on the size of parts.
My first 318 was 30 yrs ago and finding performance parts wasn't easy to find like the other guys.Now all kind of stuff mild to wild for small blocks.The beutiful thing is the guys upgrading to wild have great,cheap parts for us.318s I LOVE EM.
In addition to the above fore warning/hint/tip to approaching a 318 for more power;
Streetwise and even something pushing it....
Carb; a 650 cfm carb will go along way on a 318. Otherwise a 600 is plenty for a bolt on a stock engine.
Intake manifolds would be a Edel. Performer taking care of most chores
Weiands Action Plus for something with a bit more punch.
Edelbrocks RPM (Air Gap or not) will handle the 318 well into some serious rabid teeth as far as that engine goes. Crap, if it can propel a 340/360 into the 11's...........
Heads. What ever it came with for mild, and again for some street snooty-ness with a bowl porting and 1.88-1.60 valve back cut will do great.
If your starting to want to run well and really get some, it's a catch 22 feild.
Fully port a better 318 head like a 302 (can be expensive)
use a small vlave 360 head with nice prep work (Cheap but port size can be touchy if the combo is off)
or a Edelbrock head which is alot for a 318. A combo of both above BUT with an exceptionaly high performance ceiling for the smaller "LA" engine.
Cam slightly smaller than a 340/360 for streetabilty, slightly larger for an agressive build. Then of course, more stall and gear than the 340/360.
Lighter the car the better. And is which you really don't see 318's in a B body trying to run anybody down. The B body is basicly a bit heavy. :icon_hang:
A 318 in a lightened A body has a chance.
To be honest, anything more than a few bolt on performance parts like carb, intake, headers with a new smallish cam slid in is all I would do to a 318 in a B body. A head milling on a healty engine would be max fo a tad more compresion. There terribly low from the factory and worse in the mid 70's and on.
Skip the teen after the bolt on's (And small cam) and do a 360 or a big block for performance worthy of note.
