maddart
The engine was built by a professional engine builder. Nothing wild .40 over KB 10.1:1 compression -Cam .450/.475 lift 215/225 duration.
They also helped in the engine break in.
ok-set timing 10 degrees btc vac. line disconnected and set carb for max vacuum. Has open headers at this point. Wow this thing runs like crap. at idle it runs like it has a vacuum leak-real rough. I give it gas and it hesitates or spits gas big time.(Has a remanufactured holley 750 vac. secondary). In the 2000-3000 rpm range it sounds pretty strong.
This is my first build and i'm hoping to get some guidence.
