Hemi Rebel
- 7:21 AM
- Apr 22, 2012
- Where the outlaws live
No it's not. Millions of 318s came with Thermoquads. 800 CFM Thermoquads. That's why they are such good carburetors. You can run them on anything from a 273 to a 440 with only minor tuning and no parts changes whatsoever. Same reasoning why Chrysler used them in just that manner. Besides, what he is encountering is a lean condition. What you describe would mean the carburetor is rich, which it does not seem to be.
Yeah, check the cam specs on a 318 4bbl vs 2bbl engine. He has a 2bbl engine with a 2bbl engine cam. Let me explain how a carburetor works. Its performance depends directly on whats happening underneath of it. How much vacuum is against it and the amount of air the engine moves all comes through the carb. Putting a bigger carb on an engine does not make it run rich, just the opposite. Air passing through the venturi is what pulls fuel into the airstream. The smaller the venturi, the faster the air moves at a given speed this will draw more fuel. Open the venturi up and at the same speed the air will not move as fast thus drawing in less fuel. Which is lean. The engine isnt built to handle that much carb.
