dangina
things have slowed down due to the new kid, but I have been plugging away - heres what I have been working on:
Started putting the doors together, the regulators were filthy from years of sitting - time to work some magic:
dirty on the bottom and clean on top!
The big one - restoring a 71 rallye cluster from start to finish. This is how I did it.
what i had to start with:
no more old wiring gremlins!!!
Light switch:
high/low beam floor switch:
Wiper switch:
Temp control:
Now the hard part:
started on the gauge face plates, I used the 3M Headlight restore kit, I thought "what the hell, they're both plastic, should work for this as well" I also did this to the temp control plate as well:
Went to a hobby shop and got a paint that I thought would look close to original and this stuff was bang on and it went on beautifully with no runs - Tamiya TS-1 Red Brown. Goes on light brown but dries to what I wanted. First I sanded and painted the whole shelll:
I wasn't sure how to get the black in the wood like on the original, so I improvised, I thought if I could paint the background in a matt black and paint over top it might bleed through the paint. I used a acrylic paint which was messy to work with and it ran like crazy and pooled up alot so i had to keep wiping it down so the layer wouldn't get to thick, It was a PITA and I reccomend a different method but it ended up in my favor, I tried fingerpainting all the areas where the black was on the shell:
Next I painted a very light layer of the red brown again:
next I sanded the gauge pods and wiper/light switch areas, masked them and painted them a semi gloss:
Now this was the most stressful step of them all - applying the silver to the outer edges of the pods, switches and shell, I used a automotive GM Silver, comes as a 2 for 1, light bruch or can be used as a pen, i used the brush. It is hard to work with, you have to keep moving in one direction and it with thicken up on you if you overlap the previous area too much (it starts to dry pretty quick) This would be easy if you were a pin stripper, but for us joes its passable and didn't end up to bad:
Now all together: (I tried taking different pics in different light)
Light switch:
Wiper switch:
Temp control:
Now the hard part:
