Propwash
- 6:35 PM
- Oct 29, 2009
- Island of Misfit Toys
Hey Gent's...
Got my roadrunner on the road after a few years of ditching the wife for the garage, hiring Indiana Jones to find parts and turning my bank account into a funeral pyre. Anyways, driving around yesterday looking for trouble and the car started having some pretty significant vapor lock/fuel issues. Now granted this is a new motor and yesterday was 95F and humid, but she was having a real hard time with the heat. I shut it off and trying to restart was like trying to give CPR to a whale. Once I did get it going, it shaked and shuttered for a while. Even after a hard acceleration she wanted to die (and did once). Didn't matter if it was sitting in traffic or going down the road. Even a big bump or sudden change in pitch you could hear/feel the engine stumble. So, i'm coughing this up as a fuel heat issue, mainly because it runs great when cold and there is no vacuum leaks. Engine temp was running 190-200F.
I do have a trans-dapt 3/8" phenolic spacer under the carb (limited by hood clearance), the braided fuel line has the protective heat barrier on it where it get's within 6" of the headers. Crossovers are blocked just by design of the Indy intake. The engine itself had timing and fuel dialed in on the dyno via EGT sensors, A/F sensor and torque/HP curves and vacuum. So what would you guys recommend as the next step? Bigger spacer with a deeper drop base aircleaner? Wrap all fuel line in the engine compartment? Heat shield/sink for the carb or fuel pump? Bring up the float levels a little higher in the sight glasses (currently set at half)? Is this a matter of a few small variables, and being a new motor with the extreme heat is just adding a lot of fuel to the fire? I appreciate anyone's past experiences with this sort of issue and any remidies.
