- 12:28 AM
- Jan 1, 2013
- Mascoutah, Illinois
Man you have a nice shop and I knew I should have clicked stainless instead of original finish when I ordered the gas tank straps.
I needed to take a break from everything yesterday. I've been burning the candle at both ends for several months lately, and was starting to get run down. So I took some R& R for a day and we visited with nearby relatives.
Tomorrow will be filled with other things that I have to take care of.
One thing on the list tomorrow is to get some new glass and gloves for the blast cabinet. I cant see through what I have on the cabinet now. This needs to be done before I can use it effectively.
Hopefully on Wednesday I can remove the fuel tank and experiment with the different size pressure washer tips to see what works best.
Will keep you updated. Glad you all like the Mopar banner. I've had it for about 10 years or so. My local dealership buddies took care of me and gave it to me after a local car show.
hey now no rest for the weary...LOL...
Bud, that's no rest for the wicked, and I think this will be one wicked bird when he's done with it.
That's too funny !!!!!
Yes even when I'm not in the shop, my mind is there........... So I guess it was a physical RR more that a mental one........
I'm constantly thinking about different things and how to go about doing them.
Today I made some good progress on the "Wicked Bird". ( I like that name, I might just have to steal it from you all !!! LOL)
Removed the gas tank, vapor canister and shields, fuel and brake lines, original muffler and tail pipe hangers, rear rubber brake line bracket, all of the rubber and plastic body plugs, and trunk lid torsion bars. It may not sound like much, but I photographed every inch of how the lines were installed and how the clips secure everything to the car body. I also took a bunch of detailed pictures of how the original hangers were installed too.
Then I started blowing out the inside of the frame rails.
Once this was done I had a big mess to sweep up. Years of road dirt and some of the undercoating came off the car.
It still doesn't look like too much was done. Here are a few photos of how the "Wicked Bird" looks now......
For now it probably should be called "Dirty Bird" instead................
View attachment 143864View attachment 143865
Hopefully on Friday I can start experimenting with the different sized pressure washer tips to see what works the best.
I'll keep you all posted !!!!
That underside looks solid as well as the frame rails. I hope you don't find anymore holes other than what we can see on the driver floor.
The cowling is going to be a challenge too. Here again a complete AMD section will be used because it is just too far gone.
Luckily for us, our 71-72 B body cars share a lot with our E body brethren.
Would this be true of 73-74 B Bodies?
Not as much so for the 73-74 B Body cars. There are still some parts that interchange though. I think the main problem is in the way the K Frame bolts to the frame rails. This causes the inner front fender wells to be different and so on.
With the 71-72 model year B Body cars the majority of the inner sheet metal interchanges with 71-74 E Bodies from the front floor pan and A pillar posts all the way forward to the radiator support.
Im not 100% sure about the cowling area with your car.
I know the E Body cowling can be used on 71-72 model year cars after you slightly modify it by removing the rear upper fender mounting stud and bracket assembly from your original and welding it into position on the new part.
The front floor pan and console brackets may interchange as long as you use one from a 71-74 E Body. The 1970 E Bodies used a one year only floor pan that was flanged along the outer edge.
The same may hold true with the radiator support but any E Body year should work.
I would recommend talking directly to an AMD sales rep as well as consulting their catalog.
Some other small parts mainly in and around the cowling area may also interchange too.
Hope this helps.
I presume you are blasting it yourself?
Anxiously awaiting those photo's!
i presume you are blasting it yourself?
Yes I will be doing the blasting too. I did the Duster with a small pressure pot system. It sucked and took almost a full month to do on my off days.
Ive been talking with Donny and got some great advice. He's a great guy and I wish he was closer.
I've been toying around with the idea of starting up a small portable business in which I would be blasting car bodies and other things too.
The main drawback is the start up costs. Im looking at spending at least $20K to get it started properly with insurance, licensing etc and that doesn't include a diesel powered compressor that would put out a minimum of 195 CFM.
Honestly I just don't have the money to do it.
I would have 5 cars to do right now from some local businesses, but I'm worried about a constant check coming in afterwards. Sometimes people tell you that they will give you a shot at doing something, but never follow through with it. Right now I just can't take that risk.
But I have a plan "B" that I'm working on......
Have you seen those water based blasting systems? Maybe someone in your area is doing it or perhaps it would be cheaper for you to get into ??
