- 11:47 AM
- Apr 13, 2012
- Granite Bay CA
Pretty cool stuff. I've never been one to embrace new technology. Hell, I'm still using AOL for my email. I do drive an 07 Ram since I need a reliable work truck.
Months ago when I was neck deep in trying to tune the car after a cam swap, I installed an AEM Wideband Air/Fuel guage. The cam swap was done in an effort to stop the detonation I was having. The engine still knocked so the guage was put in to see if I had something else out of whack. I played with different jets and power valves to get the Air/Fuel ratio into a safe area. I stopped with the tuning after realizing that nothing I was doing was curing the detonation problem.
I finally realized that after awhile that the detonation problem stemmed from this basic issue: Too high of a compression ratio for the available fuel. I went with thicker head gaskets to lower the compression to a streetable level and since they were off the car, I had the heads ported. Now with it all back together, the detonation is gone and I am back to tuning with the guage.
Up until now, I tuned my cars by the smell of the exhaust, the color of the spark plugs, the way the car ran and whether or not the engine stalled when I put my hands over the carb throat. This guage beats them all by a mile. Right after starting the car after the head gasket swap, I started tuning. The guage read I was running in the 11.0 ratio at WOT which most would call Pig rich. There was no black smoke and no smell. based on my old ways, I would have thought that I was running an ideal mixture. I've reduced the primary jets, adjusted the idle mixture screws, adjusted the timing and changed to a Rev-N-Nator ignition box. The numbers are getting closer to the goals of 14.7 at cruise speeds and 13.0 at WOT. I've read several threads about carburetor tuning and many say that it is quite possible that I may never reach the goals exactly. Some say that if you get the idle reading clean, the transition to part throttle can go rich. Its just the nature of the carburetor. I'll keep digging and hopefully get close. Already the car feels more responsive after leaning it out some. It runs stronger than ever. Since it isn't knocking at WOT, I'm able to run more advance in the distributor. If you have considered buying one of these Air/Fuel guage kits, I'd say as long as you can afford it, do it. I got 12.8 mpg on a road trip last year with the carb running 12.5 to 13.0 at cruise and 11.0 to 11.8 at WOT. Not that I built this car to sip gas, but to me it makes sense to optimize the tune and waste as little fuel as possible.
