I think this is the way to go for a 70's RR https://digi-tails.com/1970-plymouth-road-runner-led-tail-light-panels
That's a very good point too 747 Mopar . . . but, it would depend on the "type" of LED lights that you get too . . .
LED can be very directional - as is the case with ones like these . . .
Or they can be "mostly" directional, like these, but shed some light to the sides ( notice the shape difference from above )
Or they can be set up, like these, to assist with shedding light in many directions . . .
Here's a pic of some LEDs that I have in the ShoeBox . . . No doubt that you can tell that I'm stopping . . . ( or backing up )
NOTE: If you do get LED bulbs for your car, then you may find out that your flashers no longer work - that's because the LED draw far less amps and don't allow the element in the flasher to heat up and disconnect.
SOLUTION: Buy an electronic flasher unit, they are made for LED bulbs and work with the LEDs and don't depend on amp draw and heat to cause the flash.
ALSO: Electronic flashers are directional, they must be hooked up properly to work. When I got mine, it did not work, called the company and they wanted to sell me $5.00 polarity swapping plug - All I did was pull the pins from the plug, and reverse them - everything worked great !
I installed the digitails on my 70 GTX. They went in easy and work just fine, although I have a completely different wiring harness. I have read where they can be problematic on the old stock wiring/power systems. A relay perhaps?? Anyway, lots of comments on the sequential turn signals!
"as goon would say those pedals are fer racing...lol."
Yer Damn Right! lol Those LED circuit boards are awesome and if I'm correct I believe they can also be programmed to light a certain way (i.e. the Led's light in succession from left to right when making a right turn)... obciously FER RACIN!!
Yup they can... found me a viiiii deeee oooo! lol
http://www.youtube.com/watch?v=DngqoI3WcOE
USARR,
I have been lurking but finally got a chance tonight to read through your entire thread. I love the plans you have for your car and it is looking great so far! Keep up the good work.
For the "C" word: There is a new class of cancer drugs that are coming out that have some great promise. One of the first is called MK-3475 and its indication is for melanoma. Your body normally attacks and kills any offending things that get in your body. But cancer hides itself and the body does not recognize it as a problem. The key with these new drugs is that they do nothing to attack cancer. All they do is "unmask" it so you body then fights it at the cellular level. They have shown some amazing results, and my hope is that a few years from now these will be standard practice.
At any rate, keep up the good fight and kick that cancer's ***. If it is stubborn, do some research on some of these new cancer drugs (I think they are typically called PD-1 drugs). I also mention this for any other member who are fighting this horrible disease.
Kick cancer's ***, then drive that beautiful Mopar like you stole it!!!
All the best,
Hawk
I want a name for mine! I've been thinking of calling it "The Time Machine", since it's taking me so much time to do.
So wiring it up....pretty straight forward or kind of a pain in the rear? Keep up the good work!
Anyone got a vid of the DigiTails in a 70RR?
