440ronnie67
lookin tuff
... And as you saw above I have a bit$h of a time with alignment because I know the frame is crooked.... I found an adjustable UCA that "might" help me get this thring driving straight OR I found a collision shop that said they can put my car on the jig with everything in tact and pull my frame for about $550..... I'm definitely leaning to the 2nd option as a proper fix.
Something I forgot to mention that I thought was kind of funny and hope I get the terminology right. I was noticing that my idle wasn't dropping down all the time when I would come to a stop... sitting around 1100 then I would have to give the throttle a shot to drop to the 7-800 rpm where it's happy.
Driving it over to the shop I noticed it wasn't giving me as much of a problem on the highways and country roads more in town.... It appears what is happening is the little switch with the counterweight on the side of the carb for the fast idle cam is getting blown up and held in the on position by the CFM (I am dubbing this the "WHIRLING VORTEX) of my fans! Going to have to build a little shroud to shield the switch from said vortex!
So what you're saying Goon . . . is when you drive the car Fer Racin' . . . it pushes the idle UP ! ! ! ( smile ) . . . Glad you're enjoying your CAR ! ! !
I want to see this torque strap go in because I'm either buying one or building one for my car. Glad your having fun with your car(whirling vortex or not) I bet it's an animal.
I really like the car! Very well done, if I had the car I would also put it on a frame table and get it straitened. I would do it in the off season too, but I would get a few freinds and carefully pull the frond clip off. That should let the frame shop correct anything they need to, and then I would carefully reassemble the front end. Sounds like a pain, but I think that would be the best in the end. For now have fun with that Road Runner!
-Mark
I love that! "WHIRLING VORTEX" I just may have a lead on some more "MOPAR" sayings to lead the way....EVEN MORE!![]()
Thanks again for the kind words and comments everyone!
I'm not going to bother with the frame work until this winter just in case it does snowball into other issues I don't want to lose any more drive time than I already am.
Here's where I am on everything "on the go"
- New Mity Mount and Shumacher torque strap have shipped just waiting on arrival.
- Poked my head around to find my oil leak this weekend... looks like it's coming from the inspection plate between the motor and trans so I'm pretty sure it's main seal
- Cal Tracs ordered gotta get rid of my wheel hop from my soft springs
- I'm still having that clutch issue where all of my play is at the very top so going to try swapping release bearing.
- New speedo gear ordered since I changed the gears
- FER RACIN!!!
LOOKS LIKE IM GONNA HAVE TO FIRE UP THE VYNAL MACHINE AND CUT OUT SOME......WAIT FOR IT.......FER RACING stickers.
A grand idea!! lol!!
could be a fatal attraction coming ..........:wav:
That is way to cool Goon, It's amazing the amount of people that just fall in love with these old cars (I'd probably leave a note in that beast too). As far as the torque strap goes I don't need anything fancy just curious how hard it's going to be to get stuffed in there and what headaches there might be. I guess just a few pics and a testimony (hopefully minus cuss words haha).
She sounds hot!
