moparjohnny
great looking work stevo,man you are moving right along.
Everything fits great except for where the trunk extension meets the bottom of the quarter at the wheel well. The gap was about an inch apart. I'm thinking the wheel house had moved a bit with all the welding and the fact the car took a hit there. But being everything fits perfect I've decided to just fold the trunk extension lip to meet the quarter in that one little area. Not a show car and no one would ever be able to catch it unless I told them. Door gap= perfect...sail panel= perfect...trunk=perfect.... All my measurements match exactly to the old quarter also... So with that being said... I'm done messing with it.Glad you dehumped before the quarter. I didn't catch it till after. Not any fun then. The quaters will work just takes lots of trimming fitting. I also found all the bends to be under or over what they needed to be. You can check my thread also for tips. Note the tail light ext. area will also be very time consuming and not even close to what it needs to be. Also be sure to fit your trunk before welding in the rear window filler panel to get your gaps right.
the undersideThanks. Good luck with the back. I fight spasms every now and then but I just take breaks for awhile. I'm a learn as I go type of person. The next car I build will be a lot easier that's for sure hahaJust read this entire post man this is a great build , your doing a great job with the road runner ,it's looking much better then when you started , I can't wait till my back doctor gives me the thumbs up to go back to work I miss doing this stuff . Good luck with the rest can't wait to see more . And are you sure you never have done body work before ? You could of fooled me
