SUPERSTOCKRACER
I gathered all new parts since September to do a bigger hemi.
It was time for a refresh anyway so I went with another Aluminum block, bigger Callies crank and now switched to Oliver steel rods. Only 225 grams heavier than the MGP Aluminum rods that needed to be replaced.
Went to a new Comp cams .798 roller cam from my old .737 roller.
New Crower lifters and new pushrods. Keeping my indy -4261RA CNC Heads and intake and going to use the new Dale Cubic Edelbrock Carbs. Engine will be quite a bit larger from the last engine. Compression will be 14.5:1
Pistons are by CP
Rotating assembly being balanced this week and assembly will be starting by the end of the week.Pics to follow.
Pistons are by CP
