Modern Bullitt build
I finished mocking up the cross member with plywood and willduplicate in aluminum. This design will eliminate the need for the over thetrans cross member. I think with a few modifications this cross member could alsobe used with a stock torsion bar suspension as well.
Pat
Had a friend weld the aluminum cross member for me and I thinkit looks great! With a little adjustment it fit as good as it looks!
Pat
I add a flange at each end and I need to weld on the endcaps to the original cross member. Also reused the original crush brace for thenew hole I added for the cross member.
For anyone interested here is a drawing of how I thinkthis cross-member could be made to work with a stock torsion bar suspension.
Pat
Cut the aft end of the trans tunnel and tacked it in placeand now it is looking close to original.
Pat
That came out really nice, great craftsmanship!
My carpet (trim parts brand) was already trimmed to the original floor and still fit after the mods if that makes you feel any better.
WOW! Just found this thread. You sir are doing an excellent job of fabbing.
That trans tunnel mod was slick, thanks for sharing.
man, keepat, this build makes me wanna throw away my tools and scrap my 1974 burn notice clone project and never touch another car again! you rock! cant wait to see this car completed! cheers :)
I made a shifter cover with a similar shape as an original 4speed cover using a wood block and a press. This will cover will be removablefor shifter access.
Pat
