Mike Gaines
- 3:24 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
Splicer I have to agree with you about the 8-3/4 rear. I still run stock axles in mine and a Detroit Locker with 4.30's and I use 30 x 9 Hoosier radials as they hook great for me. But I am surprised it is holding up good in my 3700 lb 63. I dont race alot but usually once or twice a year. Mine is a 440/493 with 10.6 comp as I built good quench in it and it runs fine on 92 pump and I also use a solid flat tappet cam. I also use the Indy dual plane with an 850 DP but would love to try a dominator one day. I do agree the strokers want alot of fuel as I had to jet up alot in my 850 when I went from a 440 to the 493. I think Mike will have a nice solid mid 10 car when it gets all ironed out and tuned in. Ron
Ron...What jets do you run in your 850cfm carb and dual plane ?
I'm looking forward to hearing about your first runs Mike.....I think you'll find you need more carburetor....I ran a 950 Holley HP before the max wedge heads and I suspect it was small...I have an Innovate motor sports air/fuel monitor/data logger on the car and it's invaluable...You'll be amazed at how much fuel a big block Mopar stroker wants...LOL
Splicer...could you give me the part number (from like Summit or Jegs) for the Innovate A/F monitor. And, does it just give you the A/F ratio readings as you go down the track or does it do more? and how much does it cost ?
