- 12:25 AM
- Aug 5, 2011
- Lisle, HELLinois!
Red Line?
The only thing i know from experience with the 440 motor is it has three weaknesses. 1: Rods should be replaced with forged H-Beams. 2: Oil system should be replaced with a Molodon single pick-up unit and the supply passage in the block needs to be drilled out yo match the port. 3: Heads should be replaced with something that flows as much air as possible! Yes, the cam & springs play a big part in getting to the higher RPM range, but if this engine is built right it will go to 7200 RPM and make power all the way there! In 1963 they came up with the Max Wedge Stage 3 heads that looked like a sewer. The car, with a push-button Auto went 11.40's stock. Heads are the key!
