I think I will simply weld along the seem of the bracket.Looks good Don, I have to do the same with my rear door lock post on both sides. That bracket makes it a pain, how would you weld that in if you were only replacing and outer rocker? There must be some guys here who have done this?
If I'm understanding what you're asking there - You can't remove the outer rocker with the door pillar in place, which is what's blocking Don's weld.
I replaced the pillars on both sides of my road runner with AMD parts. They went in slick as snot on a doorknob.
I did run into a bit of a snag!
If you notice the bracket with the 2 holes. This should get welded to the top of the rocker.
PROBLEM is I cant get at it... its on the other side, under the donor piece I JUST WELDED IN! :angryfire::angryfire:
I think the only thing I can do is to add a piece onto the bracket and have it bend to the rear. THEN I can get at it and weld it to the rocker!
Thanks kidNice! I did very similar on mine..
Do you mean notching out the k-frame? Got a pic of what your talking aboutLooks good Don. Are you going to notch out for the oil pan as well?
Yeah that's what I thought.Here are some pics, this is done for the bigger squared racing oil pans.
Hi ya SGT,Looking good Don!!! Keep it up. Once I feel you getting closer I'll start on my car again. Right now I'll a carpenter on our new used house. Are you going to the WPC swap meet this weekend?
