Modern Bullitt build
Incredible fabrication work as usual! What are you using to clean up the floor pans prior to priming them?
I use a heat gun and a putty knife to remove the factory under coat and wipe off the leftover under coat with lacquer thinner. Then I use a 6" & 3" DA sand with 100g paper to remove the factory paint.
Thank you!
Pat
The drive shaft loop/crossmember is made and tack welded in place. Back to thetorque boxes.
Pat
My god, all the work on this car is absolutely top notch. A true craftsman indeed.
I am not worthy... :icon_pray:
People wonder why some hot rods cost hundreds of thousands of dollars ... that hoop is probably worth $600. in labor !!
What are you spraying on there that won't burn off when you weld near it ???
Thank you, but I'm just a shop nut that likes working on old cars!
Pat
The time can add up quickly, Good thing I'm not paying someone to build this car I couldn't afford the labor ;-)
The paint is just black primer set back 1/8". I will follow it up with some internal frame coating after the welding.
Thank you!
Pat
Great work, I wish I could weld like that! What do you use, TIG?
Some TIG welding here and there but the loop/crossmember is all MIG welded. The key to welding is good penetration and contact. You can make any good but ugly weld look nice with a 60 grit grinder ;-)
Pat
Fit and tack welded the right front torque box. Had tobend the US Car Tool torque box on an angle and added ¼” along the floor sideto get a good fit. Both sides will need the same alteration to fit correctly.
Pat
Nice! Some of the inside paint will burn after welding, are you planing on painting again inside the boxes? I painted my subframe connectors inside before mounting them, then I sprayed with a 360 nozzle on a hose thru the holes after welding, cant see the results but I hope I covered the welds. Do you use a weld thru primer?
It's to be expected that you'll burn some paint I tried to tape back 3/8 to 1/2" anticipating some burning. Before the final paint on the bottom is applied we will coat the inside of all of the frames.
Pat
Installed the parking brake cable pass-through tube inthe frame connector. I also remove the original floor mount for the parkingcable as I’m going to install a small roller to redirect the cable along theframe.
Pat
I had a small section of the driver’s side floor with pinholes that needed to be replaced. I cutabout 18” from a new left side floor pan and grafted it along the cross memberso it would be hard to tell if it was repaired. Some high-build primer shouldmake any imperfections disappear.
Love the rollers for the cable and the super tight fit on your floor...nice work! I did the exact same thing with the tubing to get threw the subframe connector haha. Love this thread
Great work! I'm in the process of cleaning the undercoating off mine now. Found a few old repairs that I have to fix, works, but not good looking repairs. Do you think it is of any benefit to weld up some of the seams that now are spotwelded?
I don't see a downside in adding more welds especially if you're not sure of the quality of the previous repair
thank you
Pat
thank you
Pat
The bad repairs on mine has to be completely redone, I was thinking more of the factory welds, tranny cross member is spotwelded, the front UCA brackets seems to have very few welds, and there is many other places. Was just wondering if its worth putting in the work.
