TxDon
(Warning - long post)
I've had my GTX for about 8 months now, its a 440 with 4-speed and 3.54 Dana. It had a stock spec restoration back in 2001 and has been well kept since then. I love the look, ride and handling of the car but I'm not happy with the way the engine runs. Somewhere between 2001 and now the engine was modified as follows:
Everything else appears to be stock although it is so loud I think the mufflers may just be stock appearing shells. It starts OK and sounds very wicked with that "fairground" idle but the performance just isn't there. It only pulls about 12 inches of vacuum and unlike other big cam engines I've had it doesn't smooth out much as the revs go up. It doesn't really want to rev up like it should and driving at a steady 60 mph it still seems rough. When I shut it off hot the only way it will restart is with your foot to the floor as if it's flooded. I have done the following:
Except for disconnecting the vacuum advance none of this changed anything. Aftermarket A/C was added to the car and works great but if you turn it on it degrades the engine performance even more. I had a stock 440 GTX years ago and it was a very satisfying torque monster on the street or the highway, that is what I want this car to be. I'd appreciate your thoughts on ways to improve this problem, I would really rather not get into the engine unless I have to. Thanks in advance for your help.
- Very lumpy cam, no idea of the specs.
- Mopar Performance "Wedge" intake manifold
- Edelbrock 1411 750 cfm carburetor
- Electronic ignition distributor, Pertronix coil, no ignition module.
- Aluminum radiator.
- Cleaned & gapped plugs, they were a little sooty but all looked the same.
- Set initial timing at 12.5 degrees.
- Disconnected and plugged vacuum advance, this improved driveability the most.
- Verified choke was opening fully and adjusted idle mixture.
- Adjusted throttle linkage for wide open floored.
