My BUDGET 451 build... finally
Looks like we will have almost twin cars! Mine is a GTX but same colors and hood. Good move on the headers, mine is going to be broke in on the dyno so that'll save me switching them out twice. Looking good there! BTW my motor is IQ52's trick flows on 440 just a few threads below here.
Oh yeah, I have definitely been following that build. Those heads and intake are sooo sweet, man. Yeah, I'm sure glad I read the instructions on those headers lol (I mean, who even knew they had instructions?) I've seen what happens when they're used for break in, while they still look better than my old headers, the finish really does get messed up.
Also, I was talking to a buddy of mine who is into Harleys - he said with those ceramic coatings, you need to wipe the headers down with acetone before first firing them up or even a fingerprint will be permanently embedded.
Good info on the headers... I am still waffling between TTI and Doug's, but the fingerprint deal would piss me off.
Btw - I read your performance goals - 11.5's stock-ish idle, etc. Couldnt agree with you more - good performance, 100% streetable and durable combo - our goals are just about spot on, though your heads / Jim's tuning will put you way ahead of me. I think there have been about half dozen guys that have contributed their builds to this thread; all of us are somewhere in the same vicinity but all did it a different way. Very cool.
Wait, I guess it's been a while since I read your 69GTX thread. DAMN, i missed out on his port work and that big ol solid roller lol. My build is definitely your build's baby brother. That thing is gonna be a BEAST.
Engine is in and almost ready to fire. Just need to clean up / reroute some wiring, wrap the engine harness and fill the radiator and wrap up a few loose ends like throttle springs, spark plug wires, etc. Who knows... might fire it up this weekend. Oh, and I have a battery relocate kit on order, so I didn't bother repainting the old battery tray...
Oh, and I have to siphon out the old 'regular' fuel that the 413 drank and pour in some premium for the new girl.
Awesome, glad to hear the beast come to life!
I just realized the pictures of my budget didn't come through ok, so here it is again...
>>>>>STUFF I NEEDED<<<<<<
$1,100.00 Machined 400 Block with ARP studs, Machined 440 forged crank, prepp’d LY rods, ROSS 99494 Forged Pistons, Childs and Albert Moly Rings
$27.97 DUR-PDP-17 CAM BEARING PERFORMANCE CHRY
$21.97 FEL-1214 GSKT INTKE MNFLD
$55.97 FEL-KS2110 BBM GASKET SET
$69.97 KGB-CR806AM030 ROD BEARING SET
$79.97 KGB-MB555AM010 MAIN BEARING SET
$229.97 LUN-10230704LK CAM&LIFTERS CHR B V279H10
$17.95 MIL-34041 FREEZE PLUG KIT BRASS BBM
$150.00 440 source oil pan and pickup
$75.00 MP ductile iron rockers
$75.99 Melling high volume oil pump M63HV
$140.96 Smith brothers pushrods hardened 5/16" pushrods NH54A-CB
$50.00 misc bolts ("better than grade 8" from the darling bolt company)
$80.00 polish the crank journals
$14.51 fuel pump pushrod MRE 5249569 Fuiel Pump Pushrod
$50.00 windage tray and oil pump drive
$8.69 Oil Slinger P5249636
$240.00 cometic 0.060 gaskets
$22.44 MP chrome dipstick tube
$999.90 440 Source Stealth Heads
$24.95 Champion extended reach sparkplugs RC12YC
$88.49 ARP Head Bolts ARP 145-3706
$17.41 ARP 7/16" conveter bolts ARP 240732
$9.95 180 thermostat
VHT SP307 self etch primer
DupliColor DE1652 Ceramic Hemi Orange Paint
__________________________________________
$3,652.06
>>>>>STUFF I COULD HAVE DONE WITHOUT<<<<<<
$84.95 440 Source water pump housing
$16.95 440 Source billet heater hose nipple set
$28.95 440 Source billet aluminum water neck
$6.95 440 Source water pump to housing gasket
$25.00 440 Source water pump
$165.00 Powermaster PWM-75191 alternator
$280.00 Flotech ceramic coated headers
$68.00 Mini Starter DB Electrical 17466 SND0088
$675.80
>>>>>TRANS<<<<<<
$10.36 WIX 58707 trans filter
$13.28 transmission front hub seal Timken 331227H
$13.21 transmission rear seal and bushing Timken 5206
$85.82 Metco drive shaft safety loop MDL1700 for B BODY 1966-1970
$595.00 Dynamic converter 9.5" street strip converter 11795 SP 082X 6B
$275.00 Cope Racing Trans PSRM-2 Pro Street Rev manual valve body
$992.67
keep in mind that some things aren't listed because I already had them... like the carb, air cleaner, fan, fan clutch and pulleys, flex plate, ignition, some other stuff...
So I'm in for $4,327.86 into the motor minus $550 from parting out the 413...
So we're looking at $3,777.86 cash out of pocket for a stout, aluminum headed, street 451. I'll take that.
Good work. Get it to the drag strip so we can calculate the HP. How far are you from Atco dragstrip? I was out there in Sept. What was your initial timing set at, 18-20 ?
I guess I'm about hour / hour and a half from Atco I think. I'm hoping to bring it to Island Dragway, maybe visit the NENDRA guys that are on this board (bobtile, SSR). It's in northern jersey (Hackettstown area) and maybe 30 minutes from me.
Boy you got it made only 30 mins. to the strip! It's about a hour for me which still isn't to bad.
I'm definitely spoiled, and to think here in NJ (regulation hell) we still have 3 tracks within easy driving distance.
