- 8:59 PM
- May 14, 2011
- On the Ridge, TN
Ok gentlemen, as some of you know, I've been after this a long time now.
Car is a '68 GTX. 440 engine is of unknown build (builder passed away some years ago; was a lifelong Dodge tech at a dealer, so...). 4 speed, 3.55 Sure Grip.
Block is a '75, internals are all transplanted from the original '68 440 magnum as far as I can tell.
Cam is a Comp Cams Magnum, really mild - I'd call it two steps up from stock, but nothing like the 509 purpleshaft or anything.
The engine has those God-awful Hedmans that make plug changing a chore. Plugs are new Champions, RJ12YC.
Ignition is Mopar electronic conversion; I have a MSD Blaster II coil and MSD wires. Ballast recently changed to the MSD 0.8ohm to give me proper voltage to the coil.
Carburetor is a new Edelbrock Thunder AVS 650 #1805. I have installed the jets and rods indicated on the chart to go "2 steps rich" on primaries and secondaries and installed the "pink" springs , as the chart indicates in the manual.
Fuel pump is new from Mancini - the Carter "hemi" one that you can rebuild.
All new 3/8" fuel line from Fine Lines. New gas tank, new 3/8" pickup.
The engine pulls very well all the way up to 5500 rpm sitting still, zero hesitation, no drama, VERY smoothly. It didn't before I finally figured out previous owner had the wrong damn ballast on it.
She sure smells rich at idle, although there's no smoking or anything, even when goosing it.
I've just recently gone through all the compression testing (130 across the board, more or less), found true TDC and installed a new Summit harmonic balancer that is dead on; timing is set to give me 38 degrees total mechanical advance at around 2500.
Works out to about 13BTDC @ idle with this new distributor. I haven't worked on the distributor at all. Stock ECU.
Vacuum advance is disconnected; although I checked it out at about 55 degrees total when hooked up, the car just never has liked it hooked up, especially in high rpm mode. Not worried about it.
Engine was supposedly rebuilt before I bought the car 6 years ago. It might have 250 miles on it now, maybe.
Now, when driving:
Very pleasant, normal driving. Not a hiccup out of anything, takes moderate throttle smoothly. Drinks like a fish, though. No noticeable smoke out of the tailpipes.
When I row it up through the gears in stomp on it mode, the first two gears all the way to my self-imposed 5500 rpm redline are damn near perfect. No hesitation, no bog, pulls like crazy all the way up.
3rd gear - at about 5000 rpm, it stumbles just once or twice but pulls on to 5500.
I grab 4th and floor it - again, pulls great all the way towards the top of the rpms, but there's just a little stumble up towards 4800rpm or so.
It's like it's running out of something up there in the higher gears....
I can't believe it's running out of gas. Good Lord, I'm feeding it like crazy with the fuel system after all. Timing is dead nuts what the factory manual says to set the mechanical advance to and has tons of spark now (I think), so....
QUESTION:
Is it possible I'm simply running out of CFM in the upper RPMs with the 650?
If it's timing, does the stumbling indicate I have too much or too little advance?
How do it finally finish off this tuning exercise?
Thanks!
Now, when driving:
QUESTION:
Thanks!
