catfish774
Is there a thread where I can look over the pros and cons of each aftermarket cyl head anywhere?
I'm not totally sure where this is going. Heads are more then flow rates for a curtain application. There is quality and craftsmanship to think about. So a good list of heads out there would be a big help on choosing the one you need. My 2 cents
rtee007, you are looking at small block heads yeah? (Most here are referring to big block heads...)
Bruce Toth is now a member here and someone who has 40+ years porting and racing Mopar heads. If you want to get an education on every aspect of what makes heads work the best, contact him through a PM. I have talked on the phone and through text to him several times and he is a straight shooter that will help you learn what direction you can and need to go.
There isn't a head on the market that shouldn't be taken down and inspected, even the new Trick Flow heads. I've had seven of the Trick Flow heads in the shop. Every one has needed some valve guide work and they all have some aluminum bits inside the ports and have needed to be cleaned and reassembled.
