Damm... rough crowd!!!!.... Not one comment...did I say something taboo???
Sometimes it's a case of 'better not to say anything without prior knowledge or experience'
Sometimes it's a case of 'better not to say anything without prior knowledge or experience'![]()
Thanks Kiwi, I'll shut up now!
Not the case with me. I run a 28" 295 45 18 and it still spun too high for my tastes.so run the 410's with 29 inch tall tires.....you'll get the hole shot and cruise highways with no issue
I didn't mention it in my earlier post but I have run 4.10s in a similar built 440 with high stall converter (4200). I liked them, i drove the the car everywhere as my daily driver. I recall a trip from Harlingen,TX to San Antonio, Tx it took 5 hours an the car got 15 mpg. Going to my first job out of tech school. I was younger then and didn't mind sweating a little bit, the car was cool. 70 GTX, like it has been said, it depends on how you plan on using it.
What's the tune like? Initial AND total timing. I've always advanced my timing on stock engine and even more so with low compression ones. How quick is your advance curve and what carb does it have? I threw in a set of 3.91's into a bone stock 440 Challenger that was fully loaded and with a terrible exhaust system and it went 14.22 at the track. The whole car including the engine had 100k miles on it plus the rear tires were well worn and was spinning off the line. Never ran it with the 3.23's but the butt dyno said it probably would have done just as good."Punch" is a relative word! ;)
It is a generally stock motor for the most part, and I guess my past experiences have been mostly 400+hp small block stuff with minimum 3:55 gears. I just find it takes a few seconds to wind the thing up. Just not snappy or the snappy I'm used too.
the chart I sent has option of auto or 4 speedI should also mention that my brother in laws '68 GTX with a 440 4 spd was not as loose as as my auto.
Reading some past articles with people using them, yes, they hold up but I would also like to hear from others here with 1st hand experience.Is anybody running a Gear Vendors overdrive and with what gears? Do these things hold up to hard launches?
I had one in my 70 Charger. It was an older one without the mounting boss for the floor shifter. I had to make a bracket to make the floor shifter work.Is anybody running a Gear Vendors overdrive and with what gears? Do these things hold up to hard launches?
do the math 4.10 is like riding around in second gearI have a shot at a 4:10 gear for my 1969 Road Runner, 440 (not A12). 4 Speed car. it's a 3:23 rear end which just gives no snap to the car at all. I worry 4:10 is just way too much for the 440. Anyone running this in their car, and are you happy with it?
"do the math"; takes the guess work out of a lot of problems.do the math 4.10 is like riding around in second gear
