hd4406z
That is awesome, I have changed the rear as well. Went with PST Tubular front arms along with their kit.For my suspension no work was needed. If your car has a normal suspension travel then you will have to work the outer wheel well because of the way it's shaped. I worked mine with a torch, hammers, and dollies. turned out I didn't have to because my suspension travel wont allow the tire to go that far up in the wheel well. Also keep in mind I don't have a leaf spring in the way. I converted the rear suspension to a coil over set up.
