- 12:39 PM
- May 14, 2011
- On the Ridge, TN
Appreciate everyone checking in and offering suggestions as always.
Y'all are pretty darn awesome - and of course, I can't answer any of your questions right now, either because I'm ignernt or because the engine hasn't been torn down far enough - yet.
I DO have something for y'all to chew on, however:
I finally went thru the motions of using the pushrod checker.
Ok, ok, hold down your sarcastic golf clapping....
Here's what I think I've figured out so far:
-Stock pushrod length is supposed to be 9.315 (at least according to Comp Cams)
-The "new" pushrods I ordered and installed with the heads last fall are 9.295 long
-The measured length using the checker (taking out all lash but not compressing lifters) is right at 9.175 - so if I add the 0.020 to 0.040 for lifter pre-load that Miller suggests, that puts the "needed" length at 9.195-9.215, right?
Does this make sense and if so, is that enough of a difference to cause things to go wonky?
