- 1:40 PM
- May 14, 2011
- On the Ridge, TN
As I recall, I had to put a lot of down force on the intake to get the bolts started.Ha! Mixed bag stuff. Probably have my numbers wrong, but think I saw Rhodes lifters, for 'only' $200-400?
Anyway, let's get back to basics...how's that intake bolt line-up? Yeah I know...heavy. But, without gasket, which way are the manifold bolt holes, to the head holes...in, or out?
There is a chart around for the cut on intake, to keep up with cuts on the heads. Or, if in a pinch, oblong the intakes holes.
Hydraulic lifters...just keep in mind, all said and done, you don't want the tappet cup being able to make contact with the retainer ring, or clip. That's the whole idea behind pre-load, besides all-time positive contact with the push rod.
As in prybar amounts of downforce.
Now that I think about it, when I went to do the pushrod measuring thing, I tried to spin the pushrods in there now before I took the rocker shaft loose, just to see if they were all under tension/in a bind and I was able to twirl a few of them.
If my pushrods are too long, would I have been able to do that?
