dvw
I would like to see the current pushrod preload. They make shims that will move the rocker shaft. Why not try this: Get some caliper washers that will go over the rocker shaft bolts. Bolt it all down and then measure preload. More than likely your existing pushrods will work. Its hard when you are learning something new about motors, trans, bodywork what ever, it can be daunting. You don't want to make a mistake. You know none of us. I personally still think a lot about new techniques in building my own race stuff. I'm on a strict budget and can't afford to make a mistake. We don't build 20 motors a year that can be experimented on. Being cheap I've learned what works and what is taking a chance. If it is taking a chance when I recommend a fix I will admit it. Take your time, sift out opinions, ask questions, then act on it with your best guess.
you did handle that with tact and was pretty darn gentile on him. Lots of folks have no idea when they have a boar coon in the tree. Hats off to you my old friend you are a class act.
