The front servo does not need the hole blocked to activate. Doesn't sound correct, they don't normally leak much. However I have never used the sleeve repair kit. I'm assuming this is it?
http://www.sonnax.com/parts/1826-2nd-gear-super-hold-servo-kit#tabs1-instructions
If so I'd be looking at the outer sleeve seal rings. If that servo leaks it will kill the 2nd gear band in a hurry. The clutches will leak some. I use normal shop air pressure.
I'll try to explain on the centering of it...or, toss some more mud at it!Question - I got what appears to be a proper 10 inch pattern, stock flexplate from Mancini - but it still has 3/8 inch bolt holes. The stock 5/16 inch bolts are lost in them - but they are definitely smaller than 7/16 inch. So what accurately centers the converter on the flexplate - just the engine dowels? I didn't spend a lot of time looking at the crank when I pulled everything apart - does the crank center the converter snout in the bushing recess that closely? Seems sort of imprecise.
Just a suggestion, for any servo piston that uses o-rings, especially more than one o-ring.My front one is stock other than polishing the bore, replacing the seal rings and the spring/spacer swap from the TransGo TF-1 kit. I did notice that when I installed it, the lower piston slid right in with little resistance so I'm hoping it holds pressure OK.
I'd pull the piston back out. Take the upper o-ring off, and test fit the piston, with the lower o-ring in place. Pushing the piston into the bore, the o-ring should have a slight drag. If it does not, it's too small. Need to go to the next bigger size, that will fit the groove, and have some drag in the bore. If it doesn't, it will leak.
Any o-ring seal should be checked for fit...one by one...to know it's going to do the job.
O-rings have to seat themselves, to seal right.
And, what size bolts were on the converter/flexplate. Some of that aftermarket stuff can toss kinks into things.
Alrighty...like oldbee, probably had a clutch plate, or two dis-engage, so the drum assembly isn't seated. Or, something in the clutch stack isn't right, piston seated? Endplay right? That happens real easy, especially if your trying to put 'em in sideways. One of the main reasons to stand the trans up, and 'drop' the assemblies into place. While I'm at it, if you haven't done it yet...the bands...put them into place, before you stack the clutch drums in.Plus I have only about .016 end play. I may have to figure out some way to stand the transmission up on end - to get the clutches all seated. Anyone have any other suggestions.
Miller - I understand the flex plate centers on the crank hub. But is there really engagement and self-centering of the converter hub into the crank?
Errr...hint.So you'll wind up with main case, with tailshaft in place. Makes it all much easier like this...make a short stand, drum, or anything only tall enough for the length of the tailshaft. Idea is a piece of plywood, with a hole for the tailshaft to go through, holding the trans nose up, the tailshaft off the floor. The lower the better!
Page 142 in the handbook, shows the ports, to air check clutches and servos. No, the valve body is not installed, yet.I'll check out the front servo sealing further. I haven't checked to see if the valve body has to be in place first to air test it.
I found on page 9 of the "the book" that different thickness c-clips can be used on the front of the output shaft or a shim can be used on the front of the rear planetary. As you can see in the picture - I already have a shim on the front of the rear planetary.
I must be missing something - these are the original planetary sets except for the sun gear which shouldn't make a difference.
Is measuring the planetary end play with the governor and tailshaft installed still a valid test - measuring between the nose of the front planetary and the c-clip?
