Back in the shop for another round at this area . . . it's giving me a fit . . .
Sometimes it's best to find a new tool for problematic areas, are you only using the rigid wooden flat board? An area like that might be better blocked out with a contoured foam board that will conform. They're rigid enough to level the panel but flexible enough to bend making it a lot easier.Back in the shop for another round at this area . . . it's giving me a fit . . .
Look what showed up today . . . Ordered it last week ( after your referrals ) . . .
I've got some "tap magic"
Ooops . . . . that's the "other" type of tap magic that I had on my mind . . . how about this . . .
So I'm ready for my next battle with tapping threads . . . Thanks for all the advice FBBO friends . . .
At a pinch you can use your own spit as a lubricant....you'd need to get a good hefty lump from the back of your throat.
It's amazing what a gob of spit can lubricate when needed.![]()
Spit.... lubricate... this is going south quick and I'm not even going to ask where you picked this trick up!At a pinch you can use your own spit as a lubricant....you'd need to get a good hefty lump from the back of your throat.
My weapon of choice....always carry a bottle with me....you never know when you might need itI'm afraid to ask what you southern hemisphere boys use to lubricate for a cable pull through conduit!
Once he gets all the right lubes he'll pound it out in no time.What sort of time frame do you have now Larry for completion of the bodywork?![]()
Once he gets all the right lubes he'll pound it out in no time.![]()
