Anybody here own a '05-'07 Dodge magnum?
fwi
1:12 AM
BHC Arizona
Just noticing there are many for sale, most seem to have engine problems so they are dirt cheap, in the $1000-$2500 range. Is it worth rebuilding/replacing the engine? Your personal views and experience appreciated.
Which motor have you been seeing, 2.7-3.5? 3.5 is a pretty good motor 2.7 not so much
Ditto on the 3.5, great engine. However, any Chrysler product with a 2.7, 3.7 or 4.7 between the fenders should be avoided like the plague. Run away!
My wife has almost 200,000 miles on her 06 with the hemi. She loves that car.
Yes, most of these cheapies have the 2.7, so if I find one with the 3.5 then it should not be as bad? Of course a hemi one will be fine. Of course it all depends on how well it was maintained
I would pull the trigger on a 3.5 in the price range you mentioned, anything else forget it unless it's a hemi.
Some day I'd like to do a Magnum "with a Hemi" build...
I've noticed the ones with smaller engines
SXT & SE are cheap now...
all of them for the most part are decent priced right now,
the RT & especially the SRT-8 & Hemi's are a bit more
I dig the somewhat retro station wagon style,
a ton of my youth was spent in the back of a station wagon...
check out there's like 30 of them all over the US, from $1200- $10k
some SRT is $29k, he's dreaming
most are in the lower $ ranges & have over 100k miles
for example
http://www.autabuy.com
enter you criteria
for example
enter you criteria
And just why did you spend so much time in the back of a wagon?
:lol: I'd like to say it was something better
BUT,
I was a bit too young for any shenanigans:poke:
my Mom had a 57 Plymouth until like 1967 I was 8, in 67...
My step dad had a 57 Ford Ranch Wagon too,
we'd get the whole little league or pop-warner teams in it...
I agree....had one with the 3.5 V6...no problems...seems to be a great motor..stay away from the smaller V6's...lots of oil related problems. 3 .5 or hemi are great!
Seen plenty of 3.5s out there with well over 200k on them
for example
enter you criteria
Thinking the same way, always liked the wagons and think a Magnum would be a cool build. I'd love to see a Charger nose on one.
I think one would be kick *** w/ a 2013 type charger front end on it, w/ a stout big block . On another note, I`ve got a 4.7, 02 ram w/ 164,500 miles on it, never had a problem w/ it , other than front wheel bearing. And they ere the easiest to change I`ve ever done.
LIKE THE CHARGER !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I want one ! I`d almost bet they will interchange .
They do interchange fairly easily, the 05-09? 300, magnum, and charger can all be interchanged without major modification. I seen an episode of overhauling where foose swappped the Chrysler 300 and magnum front ends. I believe the Australian version of the magnums come standard with the 300 front clip
I have had my 2007 Magnum R/T for about 8 years now. Both the wife and I absolutely love it. I have only done minor things to it, but I plan to eventually supercharge it.
Magnum and 300 front ends interchange directly, but the Charger stuff, while bolting on, have different lines and the fender/door intersection is very different. You basically need to trim the (wider) Charger fender down to match the Magnum doors. The picture of the silver one has a set of fiberglass conversion fenders that just bolt on. Just goolge "Chargum" and you can learn more. The only thing I would ever trade my Magnum in on would be for an SRT Magnum.
