Good news!
That's awesome Glen, congrats!!
For timing, total will depend on the quality of gas, compression and temp. With crappy corn gas probably less than 36*
Some guys set total first by reving the motor up until the mechanical is all in, say 36*, then your initial is set as well. I never had luck with this as there was always a better initial.
The advance plate in your distributor is marked with a number, say it is marked 12*. Plate is marked in cam degrees so to get crank degerees times the number by 2. So set your initial with a vacuum gauge to highest vac reading, adjust idle as you go because the more you advance, the higher the idle. Say you get best vacuum at 16*. 12* mech x 2 = 24* + 16 = 40* total. Waaay too much so what most guys do is weld the mech plate to limit mech advance. In this case welding the plate to 10* would get you 36* total (10×2 + 16 = 36).
That bad boy needs a SS Grille!!
Thanks Mark, it's making more sense to me now. I guess to find out the initial when it's past the mark on the timing cover, I need an advance type light right?
Great hearing you've got the engine run in! The timing, yeah, the quote is one way. All in all, it's about giving the motor what it wants, and going by the fuel used. Know that sounds vague, but it works. Every engine is different...and it will tell you. Funny thing, on mine, just basic set-up, refuses to ping. But, I haven't had mine on the road, yet.Some say to advance the timing at idle (800 rpm?) with the vacuum advance disconnected until the engine starts to ping and then back off.
Nice jobyou must be pride of you
![DSCF4502[1].JPG DSCF4502[1].JPG](https://www.forbbodiesonly.com/moparforum/data/attachments/426/426623-155f4c35af3fc46b90289a76ba902671.jpg)
Looking good!
I put tti 2 1/2" pipes on mine, with h-pipe. One slight leak at the head pipe, I have to deal with...but, that's another story.
Wonder if you have the same prob(?) I have? My better half says, she 'will' drive it, once ready to go!
