WileE
- 5:16 PM
- Sep 15, 2009
- State of insanity
I've personally used 180 on my own cars for over 45 years.
None. Works fine.
Most, including me would disagree strongly.
How is running no thermostat better? Why does every factory car ever made have a thermostat?
180 deg t/stat is perfect.
I respect your view. However a thermostat does not only get engine up to temp faster, it also prevents engine running too cool in cold weather.Every car that came off an assembly line doesn't make enough power to run 121mph in the quarter mile at 3600 lbs. Mine uses a stock '65 radiator and a slightly modded clutch fan. All the thermostat does is get the engine up to operating temp faster.
What works for me may or may not work for others. Mine gets to 180° quickly and stays there. All a thermostat would do for me is restrict flow.
Conversely, the coolant needs enough time inside the radiator for it to absorb & dissipate the heat. Insufficient time will only result in hotter coolant returning back into the block.All a thermostat would do for me is restrict flow.
I also prefer a Stant....I also drill a small air bleed hole in the flange to allow easy filling and self bleed of air in the block. I would not drop below 180 degree thermostat. You do not wish to build up unwanted deposits in your block especially if this engine see mostly short local runs.
Funny - I checked it out and the builder never put a thermostat in when he rebuilt the motor. I just picked up a Stant *180 to put in this weekend. I just assumed - but wondered why the motor ran so cool. I've been running it for the last 2000 miles w/o one. Live and learn.....Hmmm - that could be. I better check that out. Never even looked. Just assumed ..... my bad for doing so.
I think he is talking about chrome t stat housings.Wait a minute I thought you were the one heavily promoting the Stant? This is what it looks like.
Yes, the housing. Thanks.I think he is talking about chrome t stat housings.
I still have the stock housing that came with the car. I don't really need anything pretty on there or see any point in changing what I have. When my thermostat comes in I'll see if there's any need to swap that out - doubt it.
