- 3:11 PM
- Mar 28, 2014
- South Louisiana
I just had my a833 18 spline swapped out and the Passon 855 installed. I want to share some impressions here and add to this as time and experience go on.
My car is a 70 V-Code Track Pak (3.54 Dana 60) Roadrunner. 71 440 aluminum 6 bbl intake and Holley carbs, FBO ignition, Mopar Purple Stripe 292* .509 cam, headers, stock short block, stock '78 452 heads with CompCams springs locks and retainers as well as 16 of their flat tappet lifters.
First thing was ease of installation. What can I say? It was easy! I replaced my tired stock cast iron flywheel with a McLeod SFI steel wheel since it was staring at me and it had visible heat cracks even after turning it a year ago.
I have only driven about 120 miles, but it has been a nice mix of stop and go, around town, and the all new and improved highway driving.
Previous to the 855 I turned 3500 RPM at 75. Now in 5th I turn 2250 at 75. What a difference! So much less noise and the 440 pulls effortlessly at the lower RPMs.
The shifter is fantastic. Tight and SOLID with extremely easy to find "gates" as I go through the gears. Positive shift engagement, crisp and clean with NO SLOP.
Now my driving habits have taken me roughly 3 hours one way to Mopars at the Battleship, but I have a trailer now and the last time I went I trailered my car. I enjoy driving it, but long (miles) drives are not on my itinerary in the foreseeable future. Long (time) cruising around is my mainstay, and I love to blast down the 1/4 mile.
That brings me to a new option that I am going to exercise with the advantage of the .70 5th gear. I am going to install a 4.10 ring and pinion to replace the 3.54 that is in my Dana 60 now. I will still be 700 RPMs less at 75 than I was with the a833 and 3.54, but I will have the added get up and go of the 4.10. For me I believe that will be a win+win.
The transmission is a little noisy in 1st/2nd but that was expected (Jamie told me it would be) and should fade with break in. It doesn't bother me at all, and with a 6XX HP/6XX TQ stroker planned i am more interested in strength than quietness.
More impressions to follow.
Looking forward to hearing from other 855 owners and some other trans swaps too like the Viper, etc etc.
Anyone with a numbers matching 3 pedal car that wants a 5 speed shouldn't consider any transmission other than the 855. No hacking or slashing with this one. My car isn't numbers matching, but I chose the 855 for its outstanding specifications, quality materials, and workmanship.
