Hopefully someone can make me feel better. I took the Coronet to a dyno days event with the new combo and numbers were WAY below what I would have expected (see photo for dyno sheet). The motor in question is my 526" (4.375 x 4.375).
My combo is as follows:
10.78:1 cr
Custom ground 262/269@.050 .715 lift Solid roller bullet cam
TF 270's (ported by Larry Smith - see flow sheet)
Indy 4150 max wedge port single plane intake (also ported by Larry)
850 mighty demon carburetor (factory jetting with 35PV)
Ultimate 8.5" 3800 stall converter just built by Lenny for my combo.
I know I am handicapping the combo with the carb but I did not expect the numbers to be that low. No way would I ever have expected the max torque to be less than 500 ft. Lbs.
The dyno guys said the numbers are low due to the converter and the dyno can't accurately reflect the true numbers because of the high stall. I watched several other vehicles that I know weren't as built as mine laying down better numbers. Can someone educate me on where they think the problem is? I will run a compression check tomorrow to make sure everything is sealing but I don't think that is the issue. I am also surprised by how low the torque peak occurs.
View attachment 523928 View attachment 523929
