dieseldazzle
Those puppies are howling like kittens when you roast them lol.
Nice work brother
Nice work brother
Nice work brother
Such a challenge without a spray booth!
Now I have to let it cure two or three days so it can be handled. I need to flip it over and do the other side.
Painting in an open garage is tough.
I've got a number of things to paint too so this is what I did. Temporary booth! 6 mil poly, 1" sq. tubing and a roll of tuck tape. Oh and a few furnace filters.
Sprayed the glass bumper today, fab'd up a swing arm, was easy to do all sides of the bumper. Glass hood to follow.
Kid.. just curious, are you using good old fashioned enamel, or base, clear? Also explain the vinegar soak recipe. I could use that one! Everything looks Great!!Did the old vinegar dip on the fender tag. I used stripper first to remove the paint then gave it a bath. I didn't want to dull the letters and numbers with sand paper. The tag was in good shape to start with. Painted it along with some misc hardware today. It's the little things!
We put the trans under the car with a jack under it and leave it back under the trans well a little until motor is dropped in. then move trans forward and bolt trans to engine, then cross-member to trans and frame. Just did an install in that order last week made it a lot easier. 512 crossram motor in a coronet with a cope racing 727 trans.
The ones above the circled one look like the ones that go on fenders to keep hood away from fenders? Picture shadow can't tell, look like the ones on my 65 Dodge.
Replacing a couple of lenses leads to a total refurbished taillight system.
Cleaned all of the lenses that I needed. Cleaned and painted the taillight housings with aluminum. Cleaned and polished the best bensils.
Replaced all of the sockets with aftermarket ones. Had to break off one of the fingers to fit the tab that's in the housing.
Wiring is pretty simple. Just match up the socket with the original for the correct bulb pin orientation and color of wire.
I'm thinking this harness has provisions for a trailer light package. Notice the female connectors inline for each wire. (Red arrows)
Another interesting find is that the lower light uses a double filament bulb but is wired for the parking light filament only.
So that gave me an idea...
This video, lights factory wired.
This video, adding a lead from the bottom light and plugging it into the trailer light connection.
Which one do you like better?
