- 12:03 PM
- Feb 20, 2012
- New Hampster
Is it supposed to work that way on a 68?
Thanks for not making me find the FSM! But are you sure? All the manufacturers do that to stop with window fogging.The compressor clutch is energized only when either the max a/c or when the a/c, (fresh air-air conditioning) push buttoms are depressed.
Taken from the a/c electrical controls and circuits section of the 68 fsm
No
Have you installed aftermarket wiring harnesses?
Do you have a factory wireing diagram?
What time delay? Thought that was only used with climate control. As far as known manual shows climate control only in Chrysler models.
68 does.It does work that way on a 69 B body. I'm not sure if 68 had the time delay relay.
