1778ppr
- 10:33 AM
- Jan 14, 2014
- South West Wisconsin
Can a 400 cast crank be neutral balanced by reducing the bob weight? In other words, Can the external balance (cast crank vibration dampener and torque converter weights) weights be eliminated by using lighter pistons, pins, rods, etc. to bring it to neutral balance? If so, what is the bob weight of a cast crank without the external weights?
Where can I find specs on OEM factory bob weights for big block cranks?
Where do you get your cranks balanced and why are you using that shop/business?
Thanks, John
Thanks, John
