69 R/T
I decided to deviate from stock by upgrading to the following parts. I'd like your input on this combo. The car is a 69 R/T with a Ramcharger hood (hood clearance) 440 Magnum with 4 speed trans and 3.54 gears. The engine pulls about 160-165 psi cranking cylinder pressure with stock 906 heads and Speed Pro flat top 9.3:1 pistons. My intent is to retain stock appearance.
QF 750 CFM mechanical secondary carb
Edelbrock CH4B intake (hood clearance issues)
440 Source Stealth heads
Pertronix Igniter II w/ Flamethrower coil
Comp Cams Nostalgia Purple Plus cam Duration 239 in. 246 ex. @.050 Lift .484 LSA 108
I haven't heard any reports on this new updated version of the old MP grind.
