Why Dominators produce lower ET's
Mike Gaines
1:24 PM
Ahwahnee, (Fresno) California
Well, a picture is worth a thousand words.
I replaced my brand new 850 cfm Holley with my new Dominator.
IT MADE 3/10'S OF A SECOND ON MY MOTOR. I AM A BELIEVER.
It looks like it's almost as big as the engine!
Whats going on mike hope too see you out there soon !! my new 500" Engine should be finished soon !!! (Dam Engine Builders) Lol
I like Dominators so much I went with 2 of them. LOL
That is the way I feel about my Pro Systems SV1 carbs.Only mistake I made was buying then from a garage hack to save $30.Have these carbs for many years and they have so many ways to tune,,,,,,,,,I'm learning!!
3.6.14 025.jpg 3.6.14 036.jpg 3.6.14 037.jpg 3.6.14 042.jpg 3.13.16 080.jpg SV1!!!!!!!!!! 003.JPG SV1!!!!!!!!!! 004.JPG SV1'S 018.jpg SV1'S 022.jpg
Jewelry there. I can't afford these big name fancy carbs. I like tweaking the out of the box Holley carbs to make as much power as I can. In fact, I was able to make these make more power than some other QFT & Demon carbs we use as test carbs. These Holley's are now also nice & street friendly as well.
Once ya get hang of it,and you have a data logger,it's amazing what you can do!!!
it's all about air. and, you need venturi area to get air.
It's hard to imagine that I can go fast with these. I did remove the choke plates,lol
Same thing happened to me - everybody kept saying 850 is the biggest you should go, car went fastest with the 1050 even on a .030 over 440. Are you into the 9's now Mike?
I'm a firm believer of giving an engine what it wants even it if means two 750's on a TR!
I raced the March Meet last month. Out of 225 cars in the bracket class I got down to just 16 cars left...then I just got beat, although I ran a 10.20 on my 10.18 dial but the guy I got beat by had an almost perfect run...he ran 11.66 on is 11.65. Next race is MUSCLE CARS AT THE STRIP (the race that I still call the MOPAR NATIONALS) at the end of this month in Las Vegas. All ready.
No 9's. 10.158 @131+ is the best so far.
I can't make any more HP from my 2 Bolt Block (even though I have a Steel Billet Girdle and Steel Billet Main Caps) because I don't want to blow the bottom end out of it.
Now my continuing "need for speed" is to shed about 150lbs off my sled to run a 9.999 and then I will be DONE.
