I just soldered up a side arm heat exchanger. The boiler water runs threw a 2" copper pipe and heats a 3/4" copper pipe that runs threw it. I hear you on the KISS method but in this case where sophistication equals a lot less wood (work) used.... I said to heck with it. Advertised as using 30-50% less woodThose pumps are neat, I haven't installed many yet, I'm kind of old school when it comes to heating systems. I believe in the KISS principle. What did you do for hot water off the new boiler?
. This has been the hold up with a lot of things seeings how you don't want to fill the garage knowing you'll have to pull it all back out for floor work.
.I suspect the floor will be one of those things where half (or more) of the people who walk in knowing what it looked like before will say "what the hell happened to your floor"! Doesn't really matter, I love the looks of stone, slate, wood and most anything nature provides so to me it's just one more thing for me to enjoy looking at to make it more like home. Now I'm torn on the cement block wall? I really hate to paint it... thought about insulating it but like being able to inspect the blocks for shifting plus don't want my conduit and outlets trapped in a potential damp area????That looks awesome 747 . . . . Can't wait to see it with the finish on it - once again, another job well done ! !
Easy enough, I'll start out with just a 90 so it's at least blowing out and not against the ceiling. Don't know how much difference it will make but it will also deliver central air as well? I do have 2 ceiling fans too so I'm sure that'll help.I'm going to suggest not having any duct work at all. My shop is very big, 75'x125'. I have one waste oil furnace set way out of the main area with the intention of adding ductwork later. I never added it because the shop heats just fine. If you want to sit way off in a corner and watch TV, you might notice it's not as warm, but in a shop, you are always moving around and will never notice it. The first pic is standing at the front looking down the shop, you can just barely notice where the noses of the blue and yellow cars are behind the wallView attachment 598993 View attachment 598992 . The second is looking down the bay of where the cars, are the furnace is in the upper left. The bay is about 20'x20'. With all the stuff in the way (trucks and walls) the heat gets everywhere. I think you'll be happy with the heat distribution and with not having duct work taking up valuable space.
I'm sure I could but I already have a mezzanine that will put the furnace 2' from the ceiling which is where it's going.I have A/C too. If you look at the second pic, in the upper left behind the two blue reels there is an A/C unit with no ductwork either. This blows down the length of the shop and also works just fine.
Can you mount the furnace to the ceiling?
I likely will because I need room for an A coil. Horizontal coils are more money and not as common so I'd like to create enough room for a standard A coil. Doing this means a 90 to turn it up for the A coil which put me right back to being close to the ceiling.Can you put the furnace in the Mezzanine horizontal and eliminate the elbow?
As you probably remember, I went with radiant floor heat. I also got a righteous (free) deal on an air handler (ac unit) and installed that. It was configured for a vertical installation but was easily converted by just moving the drain pan. I also added a back up electric heating coil to it. Zero duct work. It lays above my bathroom and blows out into the shop. Works great.I likely will because I need room for an A coil. Horizontal coils are more money and not as common so I'd like to create enough room for a standard A coil. Doing this means a 90 to turn it up for the A coil which put me right back to being close to the ceiling.
Sounds like no duct it is.... Maybe a 6" run to the bathroom because one thing I can't handle is a cold toilet seatAs you probably remember, I went with radiant floor heat. I also got a righteous (free) deal on an air handler (ac unit) and installed that. It was configured for a vertical installation but was easily converted by just moving the drain pan. I also added a back up electric heating coil to it. Zero duct work. It lays above my bathroom and blows out into the shop. Works great.
