Nice run BobI gathered a lot of info at test n tune today.
The short story is that even though the dyno liked the spacer, the track didn't . Not today anyway.
I started with 98 jets and a 2" spacer.
First pass it stumbled and went 10.16@ 134.32.
Next I took off the spacer and kept the jetting the same.
It ran 10.05@ 134.02. Still stumbled a bit off the line.
3rd pass I jetted down to 96s.
It went 9.90 @ 136.46.
The last pass I left everything the same but I stuck the air cleaner on.
9.85 @ 138.37 !!!
I wish I had a little more time to play, but I'm not giving up on the spacer.
couldn't tell the stumble, it looked like you rolled the lights
The third pass I leaned it out and ran better. Picked up 2 mph. Then picked up another 2 mph with the air cleaner.Nice run Bob
there's more in her too
sounds like it's still lean,
if it picked up with the only change being the air-cleaner
running a 9.85 @ 138 that's easily high 9.60's MPH
good luck in the future
I'm predicting a 9.70 or maybe a 9.65 in your future
with good conditions & proper tuning
the 60' alone can be 0.15 quicker, that'd get you there & then some
don't give up on the spacer either
doesn't look like the front end is coming up at all, if so not much
not transferring weight (spin)
shock or bar settings maybe {?} not knowing exactly what you have now
didn't sound like it was on the converter {?}
(I have bad speakers maybe, usually not the case thou or poor phone video/audio, quality)
in the 10.15 pass video above
No spacer yet.
BOY , I musta used to try hard !!Appears to have been a good day and if you don't red light sometimes, you aren't trying hard enough, so I've been told.
Bob![]()
Bob, you know we all are after those double 00 lights...BOY , I musta used to try hard !!
