Fuel line - mechanical pump to carb?
wsutard
2:01 PM
Seattle
Anyone know of a fuel line kit that runs from the mechanical 440 pump to a Holley double feed line?
I’m looking for all black, braided line with an fittings that runs from the pump, over the distributor, to the Holley fuel line.
I know I can make it myself, was hoping that someone had already kitted this.
Thanks.
Dang.....for black braided w/AN fittings I think make your own is your only option
You could try Summit. It's where I found all of my an fittings, carb lines and braided hose.
I used a 'kit' from jegs for my demon/mech fuel pump. I put 'kit' in quote marks because it included the proper fittings and parts BUT you do have to cut the line to fit. I prefer that anyway, it allows you to fit the line just how you want it..
It’s looking like this is the only option. Coming out of the pump, did you use a 90?
Yes, an anodized 90° and braided line up to the carb
(Sorry not enough room to get a good picture of the pump)
If you go this route make sure it has everything you need...now that I remember I may have had to buy one fitting separately
