Post your 12 second combos
12.4769sec 106mph
60ft 1.738
New personal best
The engine feels slow after 5000rpm?
Budget 440
L2355f stock bore pistons
Edelbrock E-street heads
Headman 1 3/4 headers
3" exhaust with mufflers that necks down to 2 1/4" inside
Edelbrock rpm dual plane intake
Quickfuel 850 dp with electric choke
Comp cam hydraulic 284h cam
10.1 comp
8 3/4 with 3.73 gears
Tf727 manual revers pattern
Hughes 3000 stall converter
Ss springs
10/90 front shocks
26" x 9" hoosier slicks
Shifts at 5000-5500 rpm
This was in 85-95 degrees heat
Full steel car with bench seat
My sons Scat Pack 2016 Challenger 392/6.4, 8 speed auto. Tuner box and sticky 18" drag radials. Otherwise stock daily driver. 4525 race weight. 2 weeks ago in 90 degree temp 12.01@114.55 leaving at idle letting it shift itself.
12.4769sec 106mph
60ft 1.738
New personal best
Budget 440
10.1 comp
Ss springs
10/90 front shocks
wondering whats your fuel pressure at 5000 RPM? also AFR readings? are you using street tire's? what gear in the rear?
12.4769sec 106mph
60ft 1.738
New personal best
Budget 440
10.1 comp
Ss springs
10/90 front shocks
I would bet the exhaust system is hurting you A LOT
I went with the springs that came with the heads this year. Last year I used the springs that comp recommended and it was rewing to 6000rpm easy and pulled strong (452 ported iron heads).
When I compared the pressures rates of the springs that came with the edelbrock heads, I saw that they where not that different from the comp springs.
But I think I will change back to the comp springs later on. Springs might be the problem.
As for the exhaust, I do have cut outs in my garage.
12.4769sec 106mph
60ft 1.738
New personal best
Budget 440
10.1 comp
Ss springs
10/90 front shocks
Very nice
Really like the Scat Pack cars.
Same heads I have, but I don't believe mine are ported-no visible evidence AFAIK.
My CompCams springs made the SAME improvement!
Results of my fist time ever taking a car down the drag strip. Still trying to learn how to 60' the car. Hoping for lower 12s with the current combination. Car could definitely use more rear gear. Drove half an hour to the track on 93, raced, and drove home no problems. Happy with the result for first time out!
Full weight 1966 Dodge Coronet
500 cubic in 440 stroker
Weiand tunnel ram
Dual Holley 600 carbs
906 Cast iron cylinder heads
Hooker long tube headers
Full 3" exhaust with Flowmaster mufflers
727 Trans with reverse manual valve body
8 3/4 Sure Grip with 3.23 gears
275 60/r15 Nitto nt555r drag radial
Best E.T.: 12.46
Best mph: 111.83
View attachment 636132 View attachment 636137 timeslipfirstnightout8_8_18.jpg startingline8_8_18.png
Weiand tunnel ram
Best E.T.: 12.46
Best mph: 111.83
View attachment 636132 View attachment 636137 View attachment 636138 View attachment 636139
I would put a set of 3.55 rear gears in.
Much more than that you wont be highway friendly. With 4.10 in my car I'm running 3200 RPM @ 55 MPH with the same size tire. Luckily my car is stored less than a mile from the strip.
With the stock 3.54 gears I had in my Dana 60 I used to turn 3,500 at 75 mph.
Still had room in 4th through the 1320 with a 6,200 RPM redline, but was "into" 4th far enough before the finish line so it wasn't a problem.
After I installed my Passon Performance a855 5 speed w/the .70 5th gear I went with 4.10 ring and pinion gears. Now I turn 2,750 at 75 and hit 4th before the 1/8th mile but don't hit redline before the finish line in 4th gear. Best of both worlds.
Since I spend most of my time driving outside of track days, I would have stayed with the 3.54 gears if not for the 5 speed.
Circa 1991-1993
1968 Plymouth Satellite
Re-ringed std bore 1968 440, 346 heads with a NAPA type valve job and a set of decent springs. Crower 271Hdp cam, stock rockers. Original Torker with a 780vs Holley and 1” open spacer, 1-3/4” headers, moroso underdrive pulley.
3570lb race weight, full interior, factory 11” converter, 4.10’s, 10.5x29.5 bias slicks, old SS springs(installed in 1984).
60’ in the 1.70’s, best run 12.12@112.
Prior to that I had a std Performer on the motor and a stock lower pulley.
That ran consistent 12.40’s@110.
Shifted it at 5K, and it went through the lights at about 53-5400.
I ran it one time with the street tires on the back, which were tractionless hockey pucks(Dean brand “Stinger” L60-15’s), which I got to go like 12.80’s feathering it off the line.
Only went about 107 with the shorter tires....... motor wouldn’t really pull past 5500.
3580lbs@line, All stock suspension+snubber, stock '71 340 2.02 headed motor+ HSD intake, 850DP, race hdrs, DC.590 purple sft, fmvb 727, T/A 4200 verter, 4.30's, 10x28's, best 12.39@108...1986
Here's an old one from the mid-'80s.
1972 Challenger
426 Wedge
Stock 906 heads
solid lifter cam unknown specs
Torker intake
750 Holley vacuum secondary 3310
1 and 7/8" Hooker headers
Turbo Action 3800 stall
Subframe connectors
SS springs
90/10 shocks front, 50/50 shocks rear
3.91 gears
12.82 @ 107
After I get my Promax modded Holley 3x2 bbl carbs running decently, I just got the Innovative Motorsports dual wideband O2 system. Between the new tuning tool I will have with the O2 sensors and the data that provides, and my Viking double adjustable front shocks that I haven't had any track time to even know how to adjust them, and the line lock I have yet to install, :blah:
I'm confident if I can get a handle on traction and more track time, solid 12s should await me.:moparsmiley:
6638406984243445314
6638406984243445314
1969 Sport satellite
Normal weight
12.52/ 179km/h
No prep track.
440 60 over
Source heads. Mild ported.
286 Hyd. Roller
Torker 2
Holley 750vac
Hooker super comp headers
Custom made 3000 stall but really about 2500 stall
Shift kit
3.23 gear
28x10.5 12 years old dot slicks
Stock suspension.
‘68 Road Runner. 10:1 451 cid. 906 heads with some work. Factory intake also with some work. Factory exhaust manifolds with port match. 2.5 X pipe to Pypes race pro mufflers. Custom ground solid lifter cam. HS rockers 1.6. 800 cfm Eddy carb. 3000ish converter by Cope. Stock 727 with shift kit. 3.91 sure grip. G70-14 redline tires. 3650lbs with me in. Full Stock Appearing in and out.
12.14 @ 112.93
12.14 @ 112.93
Sounds like a fantastic ride - lets see some pictures!
